Mark P.
Website: http://www.thecbandqinwyoming.comVideos: https://www.youtube.com/user/mabrunton
Brought to you by the letters C.P.R. as well as D&H!
K1a - all the way
Modeling BNSF and Milwaukee Road in SW Wisconsin
Jim
QUOTE: Originally posted by Brunton Ah, the infamous suitcase connector (also known as an insulation displacement connector, or IDC) again! You'll find people here who swear by them, and others who swear at them. I guess I'm in the latter category. No way will I use those things on my layout - they're too prone to developing conductivity problems. The blade also bites into the through wire, causing a high point-stress and fatigue multiplier, resulting finally in a broken wire. There can also be galvanic corrosion problems between the blade and the wires. IDCs may be convenient; they are not reliable. Others here will say just the opposite. [^]
Joe Fugate Modeling the 1980s SP Siskiyou Line in southern Oregon
QUOTE: Originally posted by jfugate QUOTE: Originally posted by Brunton Ah, the infamous suitcase connector (also known as an insulation displacement connector, or IDC) again! ..... Mark: Do you come by this information from personal experience or from listening to others who likewise don't like suitcase connectors? I ask because I have used them extensively on my Siskiyou Line and I have not had a single failure in 10 years of use. Not one failure - none - nada. If they are all that bad, they should have gone off the market long ago along with all the other failed inventions. My neighbor works for the phone company and they use the waterproof gell version of the IDCs all the time to do phone line repairs. He says the suitcase version we all know and love is a similar concept only without the waterproof gell added. I think what it really comes down to is personal preference, rather than a long line of failed wiring that used these connectors. [swg]
QUOTE: Originally posted by Paul3 Even these Posi-taps I have questions about. For example, do you have to strip the tapped wire, or does it pierce the insulation? Secondly, I have to question their advertising when they state in their ad (posted above) that "no tools (are) needed"...and yet step #3 tells you to strip the tap wire. Huh? I don't know about you, but I find that I need some kind of wire stripper to strip wire (IOW, a "tool"). What do they want us to use? Our teeth? Paul A. Cutler III ***************** Weather Or No Go New Haven *****************
QUOTE: Mark: Do you come by this information from personal experience or from listening to others who likewise don't like suitcase connectors? I ask because I have used them extensively on my Siskiyou Line and I have not had a single failure in 10 years of use. Not one failure - none - nada. If they are all that bad, they should have gone off the market long ago along with all the other failed inventions. My neighbor works for the phone company and they use the waterproof gell version of the IDCs all the time to do phone line repairs. He says the suitcase version we all know and love is a similar concept only without the waterproof gell added. I think what it really comes down to is personal preference, rather than a long line of failed wiring that used these connectors. [swg]
Cliff Powers
www.magnoliaroute.com
QUOTE: Originally posted by cmrproducts This suitcase connector debate will go one forever just as what is the BEST (insert subject name here)! Now those that state about soldering overhead is a problem, it can be! The easiest way I have found is to use the smallest diameter solder and have a good hot soldering gun (150 to 250 watts) (not a soldering pencil – 40 w). This will heat the joint fast and the solder will melt fast. BOB H – Clarion, PA
Ray Seneca Lake, Ontario, and Western R.R. (S.L.O.&W.) in HO
We'll get there sooner or later!
