Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Digitrax AR-1
  • Member since
    February 2004
  • 2,055 posts
Digitrax AR-1
Posted by farrellaa on Monday, March 7, 2011 8:42 PM
I finally got my reverse loop track finished today and have had the AR-1 installed for a few weeks, waiting to see how it worked and how loud the 'clicking' would be. I installed mine in a small plastic project box I had and when I ran the first loco through I didn't hear anything. I ran non sound locos and still didn't hear any 'click' but it works flawlessly every time. I am very pleased with how well this phase of my layout went. I guess if I didn't put it in the box I might have heard something. Just wanted to pass this along to anyone who may be considering using the AR-1.
    - Bob
Life is what happens while you are making other plans!
  • Member since
    January 2001
  • 6,847 posts
Posted by jrbernier on Monday, March 7, 2011 9:38 PM
  I have a pair of AR-1's and I really have to 'listen' to hear the 'click'.  I hope you a a hole drilled in the project box so you can adjust the 'sensitivity' on your AR-1.   When our club started seeing 3-4 MU'ed sound diesels, I had to adjust the AR-1 to handle the large current 'inrushes' as it tripped the AR-1.  At home, I rarely run more than two sound engines in  consist.  After all the 'doom & gloom' about arcing wheels & 'tacked' relay contacts in the AR-1  - I just never have any problems.  I am sure there may be better 'solutions' out there, but my AR-1's have given good service for the past 10+ years....
Jim
Modeling BNSF  and Milwaukee Road in SW Wisconsin
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Tuesday, March 8, 2011 5:30 AM
I agree with Bob and Jim.  I have four AR-1 units on my layout.  They all work flawlessly.  I have never had a problem with any of them.  In fact, I have never even had to adjust any of them.
I have nothing against the PSX-AR, a competitor auto-reverse unit to the AR-1.  I have never owned one.  But, from time to time, comments have been made in favor of the PSX-AR claiming that they are faster and quieter than the AR-1.  Maybe so.  I wouldn't know.  I have never made a side-by-side bench comparison.  But, as the OP said, the AR-1 is quiet enough.  I am not sure that I would even consider the operation of the AR-1 as a "click".  It is a nearly inaudible sound.  As far as the speed of the unit, my observation is that it is fast enough.  To me, the change in polarities is immediate.
The AR-1 is also half the price of a PSX-AR.  I am sure there are situations where the PSX-AR is better suited to the needs of some modelers because it also serves as a circuit breaker.  But, for most modelers, the AR-1 will work just fine.
Alton Junction
  • Member since
    December 2001
  • 1,932 posts
Posted by Stevert on Tuesday, March 8, 2011 7:55 AM
I agree with Bob, Jim, and Rich!  Thumbs Up
I have two AR-1's, both powered by one section of a PM42.  I will admit that I did have to adjust them when I first installed them, but once adjusted they've worked absolutely fine.
Both of them are installed under the benchwork, without any sort of enclosure.  If you're listening for them, and if the ambient noise level isn't too high, then yes you can hear the "click".  But I wouldn't consider it loud or objectionable in any way.  And, as already noted, they are "fast enough".  I get no hesitation or sound dropouts whatsoever.  I would not hesitate recommending them to anyone.
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Tuesday, March 8, 2011 2:47 PM
Stevert
Stevert,
Good point about the absence of any hesitation or sound dropout.  I agree, and I should have thought to mention that as well.
Alton Junction
  • Member since
    February 2004
  • 2,055 posts
Posted by farrellaa on Wednesday, March 9, 2011 9:22 AM
Glad to see some good reviews of the AR-1. I didn't adjust mine, just hooked up the four wires and let it go. I didn't drill a hole for adjustment but can see where it would be an advantage if ever needed. I can still drill a hole from the outside should I need to.  My sound engines haven't hesitated or had any reaction to the polarity change other than 'keep on truckin'.
             - Bob
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Saturday, November 19, 2011 8:27 AM
What size wires should I use to connect the AR-1 to the bus and the track?
Dean
30 years 1:1 Canadian Pacific.....now switching in HOSmile
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Saturday, November 19, 2011 9:25 AM
mactier_hogger
I use 22 gauge stranded copper wire and that works fine.
I don't think you need anything larger or heavier than 18 gauge, and I wouldn't go smaller or lighter than 26 gauge.
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Saturday, November 19, 2011 9:53 AM
Thanks Rich. I don't have one in my hand yet. I have two of them as well as a Zephyr on the UPS truck right now! Looking forward to getting DCC up and running!
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Saturday, November 19, 2011 9:55 AM
mactier_hogger
Dean
Dean,
Have fun and good luck.
Once you get DCC up and running, you will never look back.
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Tuesday, November 22, 2011 10:38 PM
Got my Zephyr todaySmile Set it up and ran a Bachman GP7, as it's the only DCC unit I have. I actually thought that the headlight was burned out until I realised that I had to turn it onLaugh Then I set to work and installed a DH 123D decoder into a Model Power Metal Train F7 ( from the Christmas set that started me down this model railroading path). While I was at it I swapped out the headlight for a Miniatronics Ultra Bright L.E.D with a 1/4 W 1K ohm resistor. Wow what a difference! The headlight would hardly come on with DC, but now it's so bright it even lights up the number boards. And it's so cool to be able to turn it on and offCool.  With that success I decided to go at my Roundhouse 2-6-0 that I recently purchased. It had L.E.D.s installed already as well as a circuit board so I just pulled the jumper and put in another DH 123D. Apart from the fact that it was a pain to work on (all those wires in the tender!) it went great. So cool to be able to run two trains at once with no blocking[<:o). ] I'm hooked on this stuffYes
Tomorrow I'll have at the first of my two AR-1's.
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Wednesday, November 23, 2011 5:55 AM
mactier_hogger
Anxious to hear how that turns out.  Good luck and keep us posted.
Alton Junction
  • Member since
    July 2003
  • 5,743 posts
Posted by simon1966 on Wednesday, November 23, 2011 8:25 AM
mactier_hogger, you are getting up to speed quickly and it sounds like you are having a lot of fun.
I now own 3 AR1's and have not had a single problem with one.   I had read so many comparisons between it and the more expensive solid state devices and had written it off from consideration.  Then one weekend I had an urgent need for a reverser and the AR1 was all the LHS had other than some MRC one that I would not even consider.   I installed it and discovered that it worked simply and with much less noise than I had anticipated based on the reviews.  It has been over a year now of trouble free operation and I am very happy with them.
Simon Modelling CB&Q and Wabash See my slowly evolving layout on my picturetrail site http://www.picturetrail.com/simontrains and our videos at http://www.youtube.com/user/MrCrispybake?feature=mhum
  • Member since
    December 2001
  • 1,932 posts
Posted by Stevert on Wednesday, November 23, 2011 10:54 AM
mactier_hogger
You should follow the same good wiring practice you would use on any other part of your layout.
For example, my two reversing sections are rather long, longer than any train I ever plan to operate, so I run my "normal" 14 AWG bus both to and from my AR1's.  Then, on the output (reversing) side, I have several sets of 24 AWG feeders from that "output bus" to the track in the reversing section.
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Wednesday, November 23, 2011 6:58 PM
Got one of my AR-1s installed today. Had a little trouble at the start. Had it hooked up to one set of feeder wires in the reverse loop  and the bus on the mainline side. DuhEmbarrassed. After reading  through the forums I realized that I had to split the bus between sides of the loop. It worked intermittently after that...sometimes the engine would stall at the gap requiring a Zephyr reset, sometimes it would stop for a half second or so then keep going. But after some time it started behaving perfectly. Almost as if it needed to be trainedBig Smile. Suffice to say I am very happy with DCC and Digitrax!!
Dean
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Wednesday, November 23, 2011 7:48 PM
mactier_hogger
Dean
Dean,
Not sure what you mean by splitting "the bus between sides of the loop".
You need to wire the feeders from the bus wires to the input side of the AR-1 and then any and all feeders inside the reversing section need to be wired to the output side of the AR-1.
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Thursday, November 24, 2011 6:27 AM
I didn't have ALL the feeders from the loop going to the output, only 1 pair.
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Thursday, November 24, 2011 6:32 AM
mactier_hogger
Oh, I see what you are saying.
When I wire up my AR-1's, I run a single set of feeders from the main bus wires to the input side of the AR-1.  Then, I join all of the feeder wire sets from inside the reversing section to a single set of feeders wired to the output side of the AR-1.
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Thursday, November 24, 2011 7:39 AM
That's effectively what I did. I had it wired originally as DC using an Atlas controller. Silly me, when I first hooked up the Zephyr I took it out and made one continuous busEmbarrassed. I'm learningBig Smile
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Thursday, November 24, 2011 7:59 AM
My point is that you can have a single set of continuous bus wires.
You just have to completely isolate the reversing section by gapping the rails correctly and routing all feeder wires from within the reversing section to the output side of the auto-reversing unit.
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Thursday, November 24, 2011 10:11 AM
Thanks Rich. That is what I've done. On another note..I think the other AR1 is defective. I swapped it out for the first one and whenever I power up a locomotive the AR1 is constantly clicking. Played with the TTC screw to no avail.Checked the Digitrax site but could find nothing.
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Thursday, November 24, 2011 10:38 AM
mactier_hogger
Dean,
If it is constantly clicking, it is detecting a constant short.  The AR-1 could be defective, but it is more likely than something is screwed up with the wiring, or something is bridging the gap, or the gaps are  not properly in place.  I have four AR-1's and none are defective.  That is not to say that yours is not defective, but I would look for other causes of the problem first.
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Thursday, November 24, 2011 12:55 PM
I'm fairly certain that it's defective. The 1st one works perfectly. I removed it from the layout and replaced it with the second one, same wires in and out as the 1st one. It clicks constantly  while a loco is moving in the reverse loop. It doesn't do that when the loco is on the mainline and it doesn't reverse polarity when the loco crosses the gap.
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Thursday, November 24, 2011 1:03 PM
mactier_hogger
So, if you replaced the good one with the faulty one, and it malfunctioned, have you replaced the faulty one with the good one to be sure that it is the AR-1 and not some other issue?
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Thursday, November 24, 2011 1:38 PM
Good idea Rich. Yes I have and it still works perfectly.
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Thursday, November 24, 2011 1:58 PM
mactier_hogger
Arrrrrggggghhhhm, sounds like you have a faulty AR-1.   Bang Head
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Thursday, November 24, 2011 2:25 PM
Hopefully I'll soon get a reply from Digitrax. I sent them an e mail regarding the problem. Don't know if I'll be able to get a replacement in time though Sad
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Friday, November 25, 2011 5:33 AM
mactier_hogger
Whatever the problem may be, if the AR-1 is flawed, I wonder if the only solution is replacement of the unit or if something on the circuit board can be fixed.  That is always a bummer when an electronic component of the layout fails.
Keep us posted and thanks for the regular updates.
Alton Junction
  • Member since
    December 2008
  • 235 posts
Posted by mactier_hogger on Thursday, December 15, 2011 4:31 PM
The AR-1 was definitely flawed. Sent it back to Digitrax on their instruction on Mon Nov. 28. Got  the replacement today. Works perfectly (with the Zephyr short circuit protection set to 1/2 a second). Now I have both reverse loops goingSmile.
Dean
  • Member since
    September 2004
  • 24,281 posts
Posted by richhotrain on Thursday, December 15, 2011 5:01 PM
mactier_hogger
Dean,
Congratulations !
Alton Junction
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
