Trains.com
Choosing the right TVS
  • Member since
    January 2011
  • 35 posts
Posted by Konga Man on Monday, January 17, 2011 8:05 AM
I've read many of the posts about adding a TVS to wiring.  One that was recommended was the 1.5KE36CA.  From looking at the datasheet, the breakdown voltage is right around 36 volts.  I run older locos ('20's -30's), and I'm using a type R transformer (because it goes to 24V).
In light of that higher output, would I need to choose a different TVS with a higher breakdown voltage (e.g. 1.5KE43A)?
Also, can I just install this by wrapping the leads around the terminals on the back of the transformers?
On a related matter, how would one determine the rating for an added inline breaker on a circuit?  I have no idea what the current draw might be for one of these locos, or for a train with 5-6 lit cars.
Thanks.
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Monday, January 17, 2011 11:17 AM
The peak voltage is the RMS voltage (24 in your case) multiplied by the square-root of 2.  This is 34 volts, still under 36 volts.  However, there is virtually no risk in going to a slightly higher rating and you eliminate any worry about the tolerance of the part; so go for it.
However, be sure you have the correct part number.  I notice that your example is the 1.5KE43A.  That is a unidirectional TVS, which is useless for an AC circuit and which your transformer will probably destroy immediately.  The "C" in the part number is essential, to get a bidirectional TVS.  So "1.5DE43CA".
Yes, the back of the transformer should work fine.
It is hard to estimate the electrical load of a train.  But I usually go with 5 amperes.  You should be able to find breakers with 5-ampere and 7-ampere ratings.
Bob Nelson
  • Member since
    January 2011
  • 35 posts
Posted by Konga Man on Monday, January 17, 2011 2:15 PM
lionelsoni
Ya know, I knew that. ;)  Crucial typo, that was.
Thanks for the clarification.
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
