Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
cleaning tracks
  • Member since
    February 2007
  • 17 posts
cleaning tracks
Posted by Jerm on Tuesday, March 30, 2010 8:21 PM
 hi,
what do you guys recommend as the best product to clean tracks?
 thanks
jeremy
  • Member since
    June 2004
  • From: Orig: Tyler Texas. Lived in seven countries, now live in Sundown, Louisiana
  • 25,640 posts
Posted by jeffrey-wimberly on Tuesday, March 30, 2010 8:37 PM
 The GLEAM method and some elbow grease. It requires a bit of work on your part but it'll cut your track cleaning to almost zilch. I GLEAMED my track in 2006 and have only cleaned the track once since then.
Running Bear, Sundown, Louisiana
          Joined June, 2004
Dr. Frankendiesel aka Scott Running Bear
Space Mouse for president!
15 year veteran fire fighter
Collector of Apple //e's
Running Bear Enterprises
History Channel Club life member.
beatus homo qui invenit sapientiam
  • Member since
    January 2007
  • 519 posts
Posted by Left Coast Rail on Tuesday, March 30, 2010 8:58 PM
I recommend you enter the terms "track cleaning" "masonite track clean", "track cleaning car" or "CMX clean" in the Search Community box over to the right side of the page where you'll discover many threads and opinions on the subject.
  • Member since
    March 2007
  • 2,751 posts
Posted by Allegheny2-6-6-6 on Tuesday, March 30, 2010 9:35 PM
 Built several of the Masonite track cleaning cars a la John Allen years a go for a total cost of nothing. I have one on every train usually and my track stays very clean. We use the same method at the club the only given is you have to clean the Masonite regularly . It all depends on how much you run your trains of course.
Just my 2 cents worth, I spent the rest on trains. If you choked a Smurf what color would he turn?
  • Member since
    September 2008
  • 1,082 posts
Posted by IVRW on Tuesday, March 30, 2010 11:15 PM
Rail-Zip, but only for worst case scenarios.
~G4
19 Years old, modeling the Cowlitz, Chehalis, and Cascade Railroad of Western Washington in 1927 in 6X6 feet.
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Tuesday, March 30, 2010 11:17 PM
A club I belong to has been in existence since 1984 and we use the John Allen method as has been mentioned. We also only use metal wheels on our rolling stock.
We run DCC locos only.
I have put a decoder in an old MDC track cleaner and run that once in a while on stub ended sidings.
We run trains every week or two. This in a walk in basement with not great heat and no humidity control.
If you ever fall over in public, pick yourself up and say “sorry it’s been a while since I inhabited a body.” And just walk away.
  • Member since
    December 2003
  • 983 posts
Posted by Marc_Magnus on Wednesday, March 31, 2010 4:13 AM
Hi,
As mentionned before I beleive the best method is gleaming the track.
Use only metal wheelset and car " a la John Allen " whith masonite pad.
May be an upgrade when the track is gleamed is cover it whith a very thin polish of "No-Ox" avaible at Walthers or directly from the manufacturer; reports say you don't have to clean track nearly anymore.
Marc
  • Member since
    September 2004
  • 24,280 posts
Posted by richhotrain on Wednesday, March 31, 2010 5:48 PM
Jerm
 hi,
 thanks
jeremy
I bought a CMX car 9 months ago but have yet to use it, although the most recommended solvent for it is lacquer thinner.  Someday, I will get that cleaning car up and running but until then, I continue to dip an old rag in denatured alcohol and rub the rails with my finger inside the rag.  Works great.
Alton Junction
  • Member since
    December 2004
  • 21,481 posts
Posted by MisterBeasley on Thursday, April 1, 2010 6:39 AM
I've got a CMX car as well.  I use it about 3 times a year.  I've tried both lacquer thinner and alcohol as the solvent, and greatly prefer the lacquer thinner.  It is, as they say in the instructions, a more "aggressive" solvent.  If you adjust the drip rate appropriately, there is very little odor, but I'd still recommend running it on a day where you can open the doors and windows and get some ventilation.
I have subways running beneath my regular layout.  Although I can get to most of the trackage by removing the liftoff sections, there are a couple of problem spots too small to reach, so a track-cleaning car is the most practical solution.
The CMX car is expensive, even when it's on sale.  But, it's a great product and does a superior job.
It takes an iron man to play with a toy iron horse.
  • Member since
    February 2007
  • 17 posts
Posted by Jerm on Friday, April 2, 2010 2:33 AM
 thanks guys for the replies
now that you mention the alcohol is rubbing alcohol the same as denatured alcohol and is rubbing alcohol safe to use on model tracks?
thanks
  • Member since
    October 2001
  • 17,574 posts
Posted by BRAKIE on Friday, April 2, 2010 3:51 AM
Jerm
thanks
Yes,91% alcohol is safe to clean track with..That's all I use and a bottle goes along way.
BTW.I also use 91%  alcohol to clean my wheels.
Larry
Conductor.
Summerset Ry.
"Stay Alert, Don't get hurt  Safety First!"
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Friday, April 2, 2010 7:33 AM
 Cleaning the track with out cleaning rolling stock wheels is like changing your cars oil and reusing the filter.
 I use alcohol and two paper towels. I lay the towels across the rails about 4 inches apart from each other (depends on how long the engine I am using) one has alcohol the other is dry. Then just run the train across them 2 to 3 times. First time I did it I was amazed at how much gunk came off the rolling stock wheels. Now I do it about once a month and there is not nearly as much gunk, but still get some.
 I am sure there are better ways to clean rolling stock wheels, but this does work.
            Cuda Ken
I hate Rust
  • Member since
    September 2006
  • 97 posts
Posted by cliffsrr on Friday, April 2, 2010 9:12 AM
My railroad Empire is in a very hostile enviroment and keeping track clean used to be quite a problem. After replacing most of the rolling stock plastic wheels with metal and gleaming the track things were much better. My next approach was to build my own version of a CMX type car. With copper pipe end caps and a coupler all soldered together to make a tank I mounted two Dremel polish felt pads in small brass tubes in the tank. A very small hole was drilled through the tube into the tank to let a very slow drip of cleanibg fluid onto the pads. Worked great. Somewhere I read that RailZip was nothing more than automotive transmission oil. I have been using a 1 to 1 mix of Trans oil and laquer thinner. By pushing this car ahead of my motive power I get good track cleaning as well as any wheels following. This has even proved to keep a few pieces of brass track clean that I am just too lazy to replace..
This rail cleaning thing pops up very often. I guess the most thing we all have in common is track
Happy Railroading
Cliff
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
