Has anyone had success making a plaster casting where the cast was quite fragile? I am trying to make a structure whose walls are like a lattice. The lattice members are about 1/8" thick and wide, and each about 5/8 inches long. The mold would be about 4" x 5" with 14 "~diamond" shaped cut outs. It seems to me that it could be strong enough to anchor onto a "wall" once complete, but just getting the structure out of the mold could be problematic without breakage.
Mike
Could you do this with resin instead? That would be much less brittle than a hard casting like plaster.
Another option might be to fabricate it with styrene strips, if you're only making one or two. You could notch the strips halfway through where they meet to get them all in the same plane.
I've worked with thin Hydrocal castings from my own molds, and they are very brittle.
It takes an iron man to play with a toy iron horse.
I use some dental stone. It is much stronger than hydrocal. It is the material your dentist uses to make models of your teeth for the lab. You have to paint it, it is too dense to stain it like you would hydrocal.
Dave
Lackawanna Route of the Phoebe Snow
I've cast a lot of fragile plaster parts. I've found that mixing Elmer's glue to the water before mixing it with the plaster helps a lot. It adds strength and I think a tiny bit of flexibility to the plaster.
Here's a little "how-to" I put together that might help.
http://public.fotki.com/daveinthehat/how-i-make-stuff/casting-plaster/
My pictures: http://public.fotki.com/DaveInTheHat/
My videos & slideshows: http://www.youtube.com/user/daveinthehat/videos
My book: http://www.blurb.com/bookstore/detail/411321
DaveInTheHat I've cast a lot of fragile plaster parts. I've found that mixing Elmer's glue to the water before mixing it with the plaster helps a lot. It adds strength and I think a tiny bit of flexibility to the plaster. Here's a little "how-to" I put together that might help. http://public.fotki.com/daveinthehat/how-i-make-stuff/casting-plaster/
In conclusion, I'm going to give plaster a try, whether it be dental or hydrocal with a bit of Elmer's glue mixed into it. If that does'nt work, I will try the resin approach. Thanks again everyone.
