Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Hooking Airbrush to Compressor
  • Member since
    September 2007
  • 19 posts
Posted by Trainsk8 on Monday, December 21, 2009 3:30 PM
i'm getting an airbrush for christmas, but i'm not sure if the hose will connect to my air compressor.  The air compressor is a Bosch and i use it for nail guns and stuff like that. but will my airbrush connect to it? or would i have to get some kind of adapter. i think the compressor has like a 3/4" connecter. the airbrush im getting is Paasche VL series dual action airbrush.
  • Member since
    July 2003
  • 255 posts
Posted by onequiknova on Monday, December 21, 2009 3:45 PM
The few air brushes I have bought came with the brass adapter needed to hook the small air hose to my air compresser.
  • Member since
    January 2002
  • 840 posts
Posted by rambo1 on Monday, December 21, 2009 3:58 PM
homedepo is the place to look of any adapters rambo1.......
  • Member since
    June 2004
  • From: Orig: Tyler Texas. Lived in seven countries, now live in Sundown, Louisiana
  • 25,640 posts
Posted by jeffrey-wimberly on Monday, December 21, 2009 4:06 PM
 As I remember my Testor's Aztec airbrush came with a plastic adapter to mate it to a standard compressor air hose.
Running Bear, Sundown, Louisiana
          Joined June, 2004
Dr. Frankendiesel aka Scott Running Bear
Space Mouse for president!
15 year veteran fire fighter
Collector of Apple //e's
Running Bear Enterprises
History Channel Club life member.
beatus homo qui invenit sapientiam
  • Member since
    April 2008
  • 5 posts
Posted by Archtekt on Monday, December 21, 2009 4:12 PM
If the airbrush does not come with the adapter, Harbor Freight has a nice braided hose with the adapter. You should also get a dryer/regulator while you are there. The regulator will allow you to fine tune the pressure for the air brush. I keep my compressor in the shop with the door closed and run a regular hose to the regulator and then the smaller braided hose to the air brush. It works great and I do not have to deal with the compressor cycling next to me.
  • Member since
    February 2006
  • 341 posts
Posted by mokenarr on Monday, December 21, 2009 4:24 PM
 if you use the compressor for nail guns i assume you have a quick disconnect at the end of the hose you have now...  I got from HomeDepot another disconnect and a brass fitting with threads on both ends than allowed me to connect the hose/brass connector that comes with the airbrush to the new disconnect, and that allows me to just connect to the airhose from the compressor...  One thing though you need the air brush connected to the hose  before you connect to the compressor to stop the air from  coming out.. Also would suggest a water filter that is in line with the brush.compressor.. A good idea with the nailer anyway
Old Steam loco's never die, they just lose thier fire.
  • Member since
    September 2014
  • 311 posts
Posted by PRR_in_AZ on Monday, December 21, 2009 6:42 PM
Like the others have said.  Go to Home Depot or Harbor Freight and get a male 1/4" threaded end quick connector.  You're airbrush hose should be 1/4" female.
Plug n Play.
Chris
  • Member since
    September 2006
  • 593 posts
Posted by duckdogger on Monday, December 21, 2009 7:16 PM
Depot over Harbor.  Even though this is not rocket science, the quality is better - things like the threads on the fitting actually mating properly with your hose's fitting.  Nothing against the Pacific rim producers, but at their worker's level of wage, QC is not foremost on any given day's to do list.
Trains. Cooking. Cycling. So many choices but so little time.
  • Member since
    January 2007
  • 24 posts
Posted by radar on Monday, December 21, 2009 7:23 PM
do,not forget the separate regulator! I think that you need a 1/4 or 1/8 adapter?
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Monday, December 21, 2009 7:32 PM
PRR_in_AZ
Plug n Play.
Chris
Correct. Paasch hoses have a 1/4 female pipe thread connector on one end. (standard male quick connect is what you want.)
  • Member since
    February 2004
  • 570 posts
Posted by basementdweller on Monday, December 21, 2009 10:23 PM
Here is how I hook up my airbrush. The orange hose is from my shop compressor, it hooks into a moisture trap / regulator and the the blue hose attaches directly to my  airbrush. Works great and all the fittings are standard stuff.
  • Member since
    July 2008
  • 98 posts
Posted by NYC-Big 4 on Tuesday, December 22, 2009 4:00 PM
I checked for adapters, fittings, etc, at Home Depot with no luck.  Found this website and ordered a regulator with water trap and a new braided hose fro my Badger airbrush to use with my Craftsman compressor.
http://www.tcpglobal.com/airbrushdepot/abfilter.aspx
It appears they have just about everything you would need for any airbrushing.
NYC Willy
  • Member since
    February 2012
  • 1 posts
Posted by oclare2043 on Friday, February 24, 2012 12:41 PM
I like your setup.  Unfortunately, I bought an airbrush compressor before doing a lot of
research.  This is way better.  I will be returning the compressor today!
  • Member since
    October 2010
  • 3,218 posts
Posted by Stourbridge Lion on Friday, February 24, 2012 3:32 PM
oclare2043 - Welcome to trains.com! Cowboy
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
