Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Sound decoder for GE 70 ton
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Tuesday, December 1, 2009 7:47 PM
Looking for suggestions for a sound decoder installation in a Spectrum HO 70 tonner with single motor.
The loco had a Cooper-Bessemer  6 cylinder, 4 cycle diesel. I will be using the LokSound micro with the speaker that comes with it. LokSound does not seem to have a similar USA sound but I have no knowledge of diesel engines. The only thing I have been told is, do not use a Alco sound as many know what Alco's sound like so they must have a peculiar characteristic sound.
Thanks.
If you ever fall over in public, pick yourself up and say “sorry it’s been a while since I inhabited a body.” And just walk away.
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Wednesday, December 2, 2009 12:20 PM
davidmbedard
 LokSound Micro....the only choice in this situation.
David B
I said that in my post. I was looking for engine type sound. There are many possibilites.
Never mind, I will figure it out myself.
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Wednesday, December 2, 2009 3:02 PM
 An online dealer suggested the LokSound Diesel Baldwin 6-VO; airhorn 72849. It is a 6 cylinder non-turbo diesel with single chime air horn sound.
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Wednesday, December 2, 2009 7:03 PM
 Search for Wolfgang's posts on his 'critters'. He's put sound in various small locos that don't use more typical GE, Alco, or EMD prime movers. Not sure which sounds he used. Loksound has a few diesel motor car sounds that should work. For casual visitors, the Baldwin would work because it's different enough from anything you're likely to hear these days, but liek Alco, Baldwin diesels have a distinctive sound that says "Baldwin".
                                     --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Monday, December 7, 2009 4:11 PM
Here are a few photos of the project. Weight, PC board, three motor capacitors, both lights removed. Only lights will be re-used.
Added 0.040" styrene board to support decoder & speaker. Decoder in place on carpet tape.
DCC control and sound is great during preliminary testing.
Working on speaker baffle now. Following a RMC, Nov. 2008 article for this install.
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Tuesday, December 8, 2009 7:07 PM
A little more progress. Again, PC board and weight not used. I will add weight in different spaces before final install of shell. I have some metal for weights that melts at about the temp of boiling water to make my own weights. I use some styrene walls to make small containers for different size weights. Lead shot works also.
Three capacitors removed
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Wednesday, December 9, 2009 2:27 PM
 A little more.
Speaker and baffle
Speaker and baffle in shell. The original article has the speaker and baffle on the styrene shelf and pointing up.
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Saturday, December 12, 2009 11:19 AM
rrinker
                                     --Randy
I found the sound from the decoder I mentioned to be quite like some You Tube videos of full size 70 tonners. I have a couple I saved made near a loco. One the engine is idling, the other is a actual Cooper-Bessemer 660 HP diesel starting and idling. That is the main engine that came with some 70 tonners.
The Baldwin VO6 sound in the decoder was also a 660 HP diesel about the sam era.
I am sure nit pickers will say no. Not the same.
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Sunday, December 13, 2009 4:07 PM
 For this install. I did not use the weight and Bachmann decoder. I poured two weights to make up for this.
Pouring weight.
Two weights in shell
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Monday, December 21, 2009 11:40 AM
mrJ
  • Member since
    March 2012
  • 9 posts
Posted by mrJ on Wednesday, May 16, 2012 6:20 PM
Hi Rich,
What type of "Pouring Weight" did you use? Is this a moldable type as you used the Lego blocks and didn't melt it?
Please kindly share that with us.
Cheers
Jim
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Wednesday, May 16, 2012 8:43 PM
The metal melts at the boiling temp of water. I put the metal in a small sauce pan. I put that pan in a little larger sauce pan that has water in it. When the water boils, the metal melts and I carefully pour it into the plastic forms while watching the scale. I found the scale on ebay for about $20..00, free shipping.
I have seen this metal sold at MRR shops in the past but I bought my stuff from McMaster-Carr some years ago for a different project, an industrial supplier that will ship to individuals.
  • Member since
    July 2006
  • 15,797 posts
Posted by hon30critter on Sunday, May 20, 2012 6:34 PM
Good videos and a good installation as well.
My only comment is that the loco starts moving before the sound ramps up. Perhaps you could play with the momentum a bit so that the motor is slower to respond and the sound comes on before the loco moves. Just a suggestion.
Dave
I'm just a dude with a bad back having a lot of fun with model trains, and finally building a layout!
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Sunday, May 20, 2012 8:39 PM
hon30critter
Dave
That video was made some time ago and I just never made a new video after fine tuning. I only wanted at the time was to show people it can be done.
I used some ideas from a 70 ton sound install in RMC, Nov. 2008, modifying a Rutland 70 ton.
  • Member since
    July 2006
  • 15,797 posts
Posted by hon30critter on Sunday, May 20, 2012 10:18 PM
I kind of figured that you wouldn't leave it like that so I withdraw my suggestion.
I am a fan of fitting things into tight spaces and your post has given me some great ideas.
Thanks
Dave
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
