Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Structures - Plastic: brick (showing mortar).
  • Member since
    December 2008
  • 160 posts
Posted by rcato on Sunday, February 1, 2009 2:20 PM
I would like to know a techniques for getting the mortar look in between the brick on HO plastic structures.
Thanks,
-RC
  • Member since
    February 2002
  • 345 posts
Posted by timthechef on Sunday, February 1, 2009 5:26 PM
Here are the three that I have used.
1. Before assembly, paint each piece with cement colored paint and wipe it off before it dries. This leaves the paint in the morter cracks. I have had some good results with this but a lot depends on how the brick is embossed in the pieces. Works good for Walthers models.
2.  Again before assembly, paint the structure with a cement colored paint and then using a fine grit sandpaper, sand the paint off the bricks. Don't sand too much or you will lose your bricks.
3. Assemble the basic structure and paint it again with morter colored paint. then choose the color you want to use for your bricks and dry brush it onto them carefully. (after the morter paint has dried of course). I have had really good luck with this on DPM products.brick wipe method This one was done using the wet wipe method
Dry bush methodThis building was done using the drybrushing method. The smoke stack was the wet wipe method.
I don't have any pictures of the one structure that I did with the sanding method.
Life's too short to eat bad cake
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Monday, February 2, 2009 5:24 AM
Chef,  Excellent work!CoolThumbs Up
Thanks for posting your photos for reference.  I have an HO Walthers Car shop building kit that I'm going to modify into a diesel locomotive shop.  I plan on weathering it using your 2nd technique.
God Bless and thanks!
"I like my Pullman Standards & Budds in Stainless Steel flavors, thank you!"
  • Member since
    February 2001
  • 3,948 posts
Posted by TomDiehl on Monday, February 2, 2009 6:36 AM
rcato
Thanks,
-RC
Before any assembly, paint the wall your brick color and allow to dry throughly. Hold or lay the piece flat, then take talcum powder and sprinkle it over the wall piece. Use your finger tip to rub the powder into the cast in mortar slots. When you have it the way you want it, hold a can of hair spray (ask your wife or girlfriend for a type that leaves her hair stiff) and mist it over the wall. The lines will disappear until the hairspray dries. This also gives a weathered look to the brick. If any accumulated around details such as window sills, you can scrape it off with a scribe or small screwdriver.
With today's fine brick detail on many buildings, I'm not sure I like the idea of sanding the brick to show the color. It also doesn't allow you to change the brick color cast into the plastic.
Smile, it makes people wonder what you're up to. Chief of Sanitation; Clowntown
  • Member since
    December 2004
  • 21,481 posts
Posted by MisterBeasley on Monday, February 2, 2009 7:02 AM
My technique is similar to Tom's.  I paint the walls before assembly, then lay them out flat and rub Hydrocal (the casting plaster) into the mortar lines.  Then I spray water gently above the surfaces, spraying horizontally about a foot above the model, so the water just "rains" down on the model.  (The pressure from the spray bottle will displace the Hydrocal, so the coverage won't be even.)  After about an hour, the water will dry leaving the Hydrocal, now hardened, in the grooves.  Wipe the walls with a damp paper towel to remove the excess.  At this point the Hydrocal will be very, very bright white.  I use a thin wash of a few drops of India Ink in water, brushed on.  This tones down the Hydrocal and gives it a mortar-gray look.
It takes an iron man to play with a toy iron horse.
  • Member since
    April 2007
  • 267 posts
Posted by MPRR on Monday, February 2, 2009 10:43 AM
MisterBeasley
I bet that would look awesome. But a quick question...
  - Does the hydrocal become brittle, and do you have to be very gentle when handling the wall/structure?
Mike
Mike Captain in Charge AJP Logging RR
  • Member since
    January 2009
  • 57 posts
Posted by grinstuff on Friday, February 6, 2009 8:19 PM
I use Polly S water base, (cement color) painted over the bricks, using wet q-tips to wipe off excess. Use your imagination as you wipe the Polly paint off...
  • Member since
    September 2004
  • 125 posts
Posted by abbieleibowitz on Friday, February 6, 2009 9:05 PM
I use a version of the wet wipe-off method described but I use white latex paint. Latex paint does not adhere that well to plastic, so it is easy to wipe off the surface brick faces, but it stays in the mortar lines. The Kalmbach book on Building City Scenery details several techniques for coloring brick and includes formulas for mixing paints for various types of washes and mortar lines. Abbie
Lefty
  • Member since
    March 2007
  • 2,751 posts
Posted by Allegheny2-6-6-6 on Saturday, February 7, 2009 11:30 AM
 I use a method described by Marty McGuirk The Model Railroader's Guide to Locomotive Servicing Terminals. after you have painted your brick wall panels with the desired color you take a "copious" ammount of water and paint the surface with it. I keep a bottle of straight water on the work bench just for this purpose and then you take a color of your choosing I use either aged concrete or depot buff and I brush it over the entire wet surface. You will actually see the color wick into the mortar line between the bricks, you then wipe off the excess with either a soft cloth or I like to use a fresh foam brush and lightly drag it across the surface of the panel. Do this as many times as you need to to achieve the look you are going for. I then assemple the building and finish it off by weathering it with chalks and finally dullcoat. I have found this works the best for me as the wwater thins out the paint so as you odn't get too much in one application. forcing you to take your time something which I have a hard time doing myself. I want the structure finished 30 minutes before I open the box in most cases.
I have done a lot of brick building his way and I like the results I personally don't care for the brick color that Walthers and most manufactures use in their panels.
Just my 2 cents worth, I spent the rest on trains. If you choked a Smurf what color would he turn?
  • Member since
    September 2004
  • 1,951 posts
Posted by wedudler on Saturday, February 7, 2009 11:58 AM
 I've painted the wall with my brick color. When dry - next day or longer - I fill the mortar lines with very thin gray color.
If you want more you can color a few bricks with a brush or crayon.
Wolfgang
Pueblo & Salt Lake RR
Come to us http://www.westportterminal.de          my videos        my blog
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Saturday, February 7, 2009 2:21 PM
Thinned down cement colored craft paint dabbed on after the building is painted and assembled. If you do it right you don't even need to clean off the brick face.
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
