Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
A good track cleaning car
  • Member since
    August 2006
  • 129 posts
Posted by Dan The Man on Tuesday, July 8, 2008 11:37 AM
I've been looking around for a good track cleaning car, I have a Caboose but that doesn't really work well. Just wondering what you all use? And if anyone can recommend me one.
I just have a 4x8 table layout, with to loops.
Thanks
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Tuesday, July 8, 2008 11:47 AM
Dan-I had one that was based on a John Allen design.It was a piece of masonite with two nails glued to it.I drilled two holes in the bottom of a box car and inserted the nails.The masonite goes smooth side down and the front and back edges are beveled to avoid catching it on anything.Just put the car anyplace on your train and run it. It does a good job.Bob
  • Member since
    August 2006
  • 129 posts
Posted by Dan The Man on Tuesday, July 8, 2008 11:53 AM
Thanks FoulRift, thats sounds interesting but pictures of this would be very helpful.
  • Member since
    June 2006
  • 1,808 posts
Posted by Lillen on Tuesday, July 8, 2008 12:06 PM
The usual answer is the CMX clean ´machine. I got one and I love it. It is kind of pricey but for me atleast it is wort every single penny.
Magnus
Unless otherwise mentioned it's HO and about the 50's. Magnus
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Tuesday, July 8, 2008 12:47 PM
Sorry Dan-don't have a picture but I'm sure if you searched you can find one besides I think Lillen has a better idea so please forget about mine.
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Wednesday, July 9, 2008 12:46 AM
I wouldn't say forget about it. I used an old Tyco 60' box car to make mine. Works pretty good if you don't feel like spending $100.
You can get the general idea. I spring loaded mine so I added a bunch of weight to the car to keep it from derailing. I just use some 200 grit sand paper to sand the gunk off the pad once in a while. Not too bad for a pile of free junk.
  • Member since
    February 2002
  • 533 posts
Posted by CascadeBob on Wednesday, July 9, 2008 5:54 AM
loathar,
How thick is the Masonite?  It looks like 1/8".  Where did you get 1/8" Masonite with a rough surface on one side?  All the 1/8" hardboard I've seen is smooth both sides.
Bob
  • Member since
    January 2008
  • 558 posts
Posted by Scarpia on Wednesday, July 9, 2008 8:02 AM
Thanks for the pictures, Lothar.
Any idea why nails over screws?
Thumbs Up [tup]
I'm trying to model 1956, not live in it.
  • Member since
    April 2007
  • 966 posts
Posted by CSXDixieLine on Wednesday, July 9, 2008 8:15 AM
Any idea why nails over screws? Thumbs Up [tup]
The nails don't really attach the masonite "pad" to the car, they merely serve as alignment pins to hold the pad over the track as the car goes around. The pad is actually floating on the rails and being pushed around by the car. This allows the pad to move up and down over any track irregularities without derailing the car. The weight of the pad alone should be enough cause it to press down on the railheads causing any gunk to stick to the pad. Also as mentioned, beveling the leading/trailing edges of the pad will prevent it from getting caught on anything sharp like an uneven rail joint or turnout frog. Jamie
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, July 9, 2008 9:40 AM
Loathar-I did have one way back when.On mine the nails were glued to the side of the masonite away from the rails and I had the smooth side facing the rails.I was amazed at the amount of crud it removed.As to my comment above"seek and you shall find"  There is even a picture of it in Andy Sperandeo's book and wiring a layout-Bob
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Wednesday, July 9, 2008 10:29 AM
It's 1/8" masonite. It comes smooth on both sides or rough on one. I used a romex wire nail like these.(cut the plastic "U" in half)
http://www.mobilemart.com/product.aspx?sku=79325
The nails fit very tight in their plastic "U" housing and holds the pad very well when you pick the car up. I wanted the pad to "float" so I didn't want to use screws. I tried just putting weight on top of the pad(with no springs) and you can't fit enough weight in the small space between the pad and car frame. The pad didn't seem to have enough pressure against the rails. I took a spring out of a ball point pen and cut it down and that provided a lot of down pressure but lifted the car wheels off the rails. Enter...the fishing sinkers...Big Smile [:D] A little bit of tweaking the springs and weight and it works pretty good.
My masonite pad is too long. (3") I would go about 1 1/2" if I built another one. You can see by the dirt pattern on the bottom that the middle of the pad doesn't contact the rails as much as the ends due to bumps and dips in my track work. I think a shorter pad would work better.
I might try a piece of sticky back 1/8" cork on the pad to see if that cleans any better than the rough masonite surface.
I'm thinking about painting and decaling this and the Geep that pulls it in CSX mow orange scheme. I'm sure the $100 brass cars work much better, but that ain't in my budget.Smile [:)]
  • Member since
    May 2005
  • 1,329 posts
Posted by Autobus Prime on Wednesday, July 9, 2008 10:52 AM
Folks:
Here's the V&E version of the famous John Allen Slider Car:
I discovered that Life-Like trainset 40' boxcars' weight-retainer bosses are nearly perfectly placed for drilling out, and are even cored partway through to center the drill. :) I didn't weight the car, just the slider, with large acorn nuts, as big as would fit. They work well and make fun clicking sounds when the car is running. The slides are held onto the nails by hot glue or CA.
The pads are easily interchangeable. Here is what I have:
-Dry masonite pad: a section of masonite pegboard, rough side down, with ends beveled, used frequently to burnish rail and remove dust. I usually tow it behind a LL F7 while I am doing other stuff. I clean it by wire-brushing or sanding. It does pick up a lot of scunge.
-Polishing pad: a piece of wood wrapped in 1200-grit crocus cloth, used after I haven't run trains for a while. Crocus cloth uses an extremely fine abrasive (jeweler's rouge), probably finer than a lot of metal polishes, and leaves a mirrorlike finish.
-Wet cleaning pad: a piece of wood with self-adhesive felt. The pad is dampened with 91% isopropyl alcohol, and then the car is run for a while. I follow with the polishing pad to loosen any stubborn crud, and then the masonite pad to pick up any residue.
These cleaners do seem to work, although I have never made any real analysis of their merits. It does seem to keep my brass track clean with only an occasional go-round with alcohol and a rag. In fact, I can't remember when I last went around with a rag...some spot cleaning has been done but nothing general.
One last bit - I have a 1/2" diameter x 1/16" thick NdFeB magnet stuck to the bottom of my Life Like F7 to pick up any loose nails or metal bits.
It's really cheap and it really works. That's what I like.
 Currently president of: a slowly upgrading trainset fleet o'doom.
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Wednesday, July 9, 2008 11:55 AM
Autobus Prime-Doh!Dunce [D)] I never thought about putting weights on top of the nails INSIDE the car!Blush [:I]
  • Member since
    August 2005
  • 3,246 posts
Posted by modelmaker51 on Wednesday, July 9, 2008 7:52 PM
Boy, some of you must have some very dirty environments! I use CRC 2-26 electronic cleaner HD/Lowes) sprayed on a lint-free cloth and wipe down all the rails once or twice a year. Yes, I do run DCC and 60% of my cars have plastic wheels, (I do have a finished ceiling).
Jay
C-415 Build: https://imageshack.com/a/tShC/1
Other builds: https://imageshack.com/my/albums
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Wednesday, July 9, 2008 8:56 PM
Modelmaker51-YEP! Outbuilding with unsealed cement floor.Dead [xx(] I was using Goof Off/alcohol every few days. Now with that CRC 2-26, I'm only using that about once every month or two.
Between the 2-26 and this home made cleaning car, I'm NOT pulling my hair out anymore.
  • Member since
    February 2008
  • 423 posts
Posted by Margaritaman on Wednesday, July 9, 2008 9:19 PM
Magnus
Me too and never looked back.
  • Member since
    June 2006
  • 1,808 posts
Posted by Lillen on Thursday, July 10, 2008 4:16 AM
 Margaritaman wrote:
Magnus
It's unbelievably good. I'm doing construction on my layout and the only cleaning I do is with the CMX. I will pass the white glove test after a single run even in this under construction dirty environment. It is more then worth the money.
Magnus
  • Member since
    February 2006
  • 1,987 posts
Posted by jbinkley60 on Thursday, July 10, 2008 4:36 AM
 Margaritaman wrote:
Magnus
Ditto ..    (I miss that icon)
Engineer Jeff NS Nut
Visit my layout at: http://www.thebinks.com/trains/
  • Member since
    August 2006
  • 129 posts
Posted by Dan The Man on Thursday, July 10, 2008 11:10 AM
Thanks guys, even know the CMX looks great, but thats out of my price range.  So I'll have to try and bulid a home made cleaning car.  Just might try the box car, pad thing.
  • Member since
    September 2004
  • 1,951 posts
Posted by wedudler on Thursday, July 10, 2008 3:07 PM
The best way:
     Run your layout !
 But sometimes I have to clean the tracks. At first place there's my Track Cleaning Transfer Caboose.
This works like a Centerline track cleaning car.
Then I bought from Lux a Vacuum Cleaner Car.
And the last purchase was the CMX machine.
This car is excellent for fluids and cleaning. Here's a video.
Wolfgang
Pueblo & Salt Lake RR
Come to us http://www.westportterminal.de          my videos        my blog
  • Member since
    February 2002
  • 533 posts
Posted by CascadeBob on Thursday, July 10, 2008 7:35 PM
What is the cleaning fluid that is used in the CMX track cleaning car?  Is this car available in N scale?  Anybody have a web address for the manufacturer of the CMX car?
Bob
  • Member since
    September 2004
  • 1,951 posts
Posted by wedudler on Friday, July 11, 2008 6:07 AM
http://www.tonystrains.com/products/tteexclusive_cmx.htm and read the manual and user reviews.
Wolfgang
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Friday, July 11, 2008 9:57 AM
http://www.tonystrains.com/products/img/showimage.html?CMX%20Clean%20Machine|tte|7|2|cmx-0210-600.jpg|cmx-0224-600.jpg|cmx-0253-600.jpg|cmx-0321-600.jpg|cmx-289-600.jpg|cmx-293-600.jpg|cmx_ho_in_black.jpg
Now I'm confused. How does the fluid get from the tank to the pad?? These doesn't seem to be any direct conection between them. I didn't realize you can buy that pad and mount assembly and add it to your own car. $30 is more reasonable than $120.
  • Member since
    June 2006
  • 1,808 posts
Posted by Lillen on Friday, July 11, 2008 10:00 AM
The fluid drips down from the tank in a very controlled manner on to the pad. Works like a dream.
Magnus
  • Member since
    May 2005
  • 1,329 posts
Posted by Autobus Prime on Friday, July 11, 2008 11:16 AM
Magnus
L:
Mr. Google tells me that this fluid is usually acetone, so it should indeed work like a dream. Of course, I could easily get the same effect on my small RR by using my $1 or so "wet-cleaning" pad mentioned above, and just dampening it with acetone instead of alcohol solution. It doesn't take much felt to hold enough solvent to clean a whole 4x8. I can honestly say I've never experienced solvent-flooded tracks or pads that dried out too quickly to clean the rails. I should try acetone, but I hate to buy a whole quart of it. It's not a solvent I use for anything, really, and it's pretty volatile.
I could certainly see advantages in a holding tank for a very large RR. Plus, people like fun stuff like holding tanks and vacuum cleaners. It gives the scale folks an operating-accessory outlet we don't normally get, because we're embarassed someone will see us if we run exploding target cars and log dumps. [;-)]
One thing I've seen mentioned on pages that talk about the CMX is the use of drywall screen to clean track. 250 grit seems /way/ too coarse.
  • Member since
    June 2003
  • 2,047 posts
Posted by claycts on Friday, July 11, 2008 11:28 PM
Kind of late on this thread but I use the box car from Walther's which is just what you are building, prebuilt. I also have that Electro II static cleaner that I drag around but no clue if it works. My edge is the environment for the layout, dust free, a/c stays at 70 deg with 45 to 50% humidity 365 days a year. PLUS I run a train everyday to just keep things going.
Take Care George Pavlisko Driving Race cars and working on HO trains More fun than I can stand!!!
  • Member since
    June 2005
  • 1,279 posts
Posted by Rotorranch on Saturday, July 12, 2008 12:08 AM
Nowhere as trick as the CMX, but it works for me!
It's one of my old Life-Like track cleaning cars. I don't put fluid in the tank, I just wet the felt pad with isopropyl alcohol, and run it. I very seldom run it anymore, as I don't have much trouble with dirty track these days.
Rotor
 Jake: How often does the train go by? Elwood: So often you won't even notice ...
  • Member since
    September 2003
  • 5,444 posts
Posted by mobilman44 on Saturday, July 12, 2008 8:19 AM
Good Morning!
I've had an 11x15 HO layout for sometime, and have tried various commercial "stuff" to clean the tracks.  Some work better than others, but to be perfectly honest - nothing works like the ol "0-5-0" track cleaner.  Whether you use a liquid or very, very fine abrasive, doing it by hand is the only method - my opinion - that will do the job as it should be done.
Of course there is trackage that you can't reach easily, so I recently purchased the aluminum "stick" from Walthers that has an abrasive on the end to reach hard to get to places, and that solves that problem.
Oh, prevention is something to pursue, and I find that installation of metal wheels has been a real help.  And fortunately, the layout is in a climate controlled room and dirt is not a major problem, as I only have to clean about every 6 months or so.
For what its worth.......
Mobilman44
ENJOY  !
Mobilman44
Living in southeast Texas, formerly modeling the "postwar" Santa Fe and Illinois Central
  • Member since
    September 2006
  • 678 posts
Posted by dale8chevyss on Saturday, July 12, 2008 1:05 PM
I have one of those CSX box cars from Walthers that cost me about 15 bucks with one of those "brite boy" pads on the bottom- it works well on my 4X8 because I didn't want to spend 100 bucks on a brass one.
Modeling the N&W freelanced at the height of their steam era in HO.
 Daniel G.
  • Member since
    June 2003
  • 2,047 posts
Posted by claycts on Saturday, July 12, 2008 10:22 PM
We have a main line of 7.7 scale miles and that is what we use. Spent the big bucks but like you we use the CSX to do 99% of the work
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
