Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Swing Gate and Turntable Pit - photo intensive- New Pics June '09
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Wednesday, May 7, 2008 2:15 AM
June 2009 - Finsihed the scratchbuilt turntable.  Was quite a long time coming.  Several parts had to be re-done to get it right.  Here are a few pics.
Here is the longview:
Connection to the bridge:
Close up of the pit rail:
 Underside of the bridge:
One more
Now to scenic the area and build the engine house.
Guy
Jan. 2009 - Thought you might enjoy an update on the projects-
Added a an arm to the gate and built a trestle on it:
Scratchbuilt trestle:
Another view:
Overview of scene:
Still more to do on the trestle underbrush.
Turntable update:
Scratch built the bridge from styrene based on the Sierra RWY Jamestown TT.  The cardboard engine house is based off of the Yosemite Valley roundhouse in Merced.  The pit is cast hydrocal.  Am currently truing up the bridge trucks to track accurately on the pit rail.
Scratchbuilt bridge
That's it for the update..For anyone who is interested contact me via PM for a PDF of current layout progress
Guy
Thought you all might like to see another version of a swing gate.   I built it following plans in the recent RMC article on swing gates.  It will have a low SP trestle on it when I get a chance to get to the LHS for wood. (click on photos to enlarge)
View from outside the room
 View from the layout side
Swinging at you
Swinging away
Detail of connection side
Next a quick look at a turntable project:
first cut a hole in the layout for the pit
now add the pit floor
now add the ring rail level
now add the pit wall layer
detail of the layers.
Lots of fill and cutting still to do.  Pit wall will be faced with a styrene strip to give an even face to the wall.  The bridge will be scratchbuilt and the drive is a hand crank set up from Diamond Scale.  Prototype is the Sierra Railroad turntable at Jamestown CA.  I made it about 20 scale feet longer than the original.
Guy
see stuff at: the Willoughby Line Site
  • Member since
    February 2005
  • 12,914 posts
Posted by tomikawaTT on Wednesday, May 7, 2008 5:37 AM
Ver-ry nice!  It's a refreshing change to see the basic carpentry.  Your gate, especially, looks incredibly solid.
Also looking forward to seeing the finished product.  Please keep us posted.
  • Member since
    December 2004
  • 11,251 posts
Posted by SpaceMouse on Wednesday, May 7, 2008 5:47 AM
Good job on the gate.
The weak point will be the screws on the hinge. Glue will help that. You can do it now or later after they start to pull out. If you wait, replace the current screws with longer ones. Allow the glue to dry before you re-hang it.
If you want to avoid the issue altogether, you can use machine screws with a nut, washer and lock washer. on the wood side.
Chip
Building the Rock Ridge Railroad with the slowest construction crew west of the Pecos.
  • Member since
    December 2004
  • 21,484 posts
Posted by MisterBeasley on Wednesday, May 7, 2008 6:57 AM
I was thinking the same thing.  I also like the way you notched down the surface.  I presume that you're going to put that trestle up on piers, and the notch will be the ground level with the bridge above it.  Will it be water or a dry wash?
It takes an iron man to play with a toy iron horse.
  • Member since
    July 2004
  • 5,199 posts
Posted by bogp40 on Wednesday, May 7, 2008 7:57 AM
Some excellent carpentry and design. With bridge abutments and piers that low bridge section will be a diorama in itself.
One note, as Spacemouse found is the weak point at the hindges. The boxed swing gate is strong itself however, that weight could soon be a problem for misalignment as it droops. There is no provision for a swinging brace back to the benchwork leg. Also, is that unbraced leg solidly fixed to the floor? Standard door hindges do have play as you found just from mounting. Piano hindges have the least play and wear quite well.
You still can add a brace and hindge to the leg. I would provide a mounting that will allow for future adjustments to compensate for any sagging/ droop. You can also slightly bevel the bottom of the gate at the interlock shelf. This will stop you from having to lift the gate if even the slightest sag starts.
You have done one excellent job on this, I am only trying to head off any future troubles for operating this great work. I hang all my doors to hopefully last 20-30 years or 'til the thing is worn out.
The rest of that layout is fantastic.
Modeling B&O- Chessie  Bob K.  www.ssmrc.org
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Wednesday, May 7, 2008 10:53 AM
You and Chip bring up the points that had me worried.  The hinges are attached with very long screws.  They are ball bearing hinges.  I didn't glue anything because I want to be able to adjust and possibly redo the gate if it doesn't hold up.
 Both sides of the gate have supports bolted into the concrete floor at the bottom and solidly attached to the walls on the ends.
The leverage factor on the end of the gate is an issue.  I was considering adding an angled brace if things start to move too much.  The gate comes back to the same spot exactly and the metal strike plates that the end rests on in the pocket should prevent too much wear alignmnet problems.  If the sag gets to be excessive, I will put in the brace.  As it is right now, I can still duck under it.  This is something I would rather not lose as an option.
In sum, it is an experiment.
Guy
  • Member since
    August 2007
  • 178 posts
Posted by mikebo on Wednesday, May 7, 2008 12:51 PM
Guy,
Just curious what are the approx. dimensions of your swing gate and what thickness plywood did you use?
I like the ledge you have the end of the gate resting on, I have a gate in the plans and always thought that was the way to keep the vertical alignment in check.
Mike Modeling Maryland Railroads in the 60's (plus or minus a few years)
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Wednesday, May 7, 2008 1:35 PM
Mr. B:  Underneath the trestle I probably will do a low lying river bottom look common to the central valley in CA.  No water if I can avoid it.
Mike,  The plans came from an Article in July 2007 RMC "Building a Model Railroad Gate" by Fred Headon.  My gate is approx 36" X 6" wide X 9" tall at the ends .  Plywood on the sides is 1/2", on the bottom is 3/4".  I would probably use 1/2" on the bottom if I had it to do over to save some weight.   There is a 2" x 4" in the gate at the hinge attachment point to provide a solid surface for the hinges.  The side frames are kiln dried, straight and true (expensive..) fir 2" X 4".  The fasica on the pocket side is 3/4" ply.
Guy
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Friday, January 9, 2009 4:04 PM
Added new material - see the top posting
Guy
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Saturday, January 10, 2009 12:44 AM
That's an impressive tressel! I love all the bolt detail.
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Saturday, January 10, 2009 11:03 AM
loathar
Tom,
Thanks for noticing the bolt detail.  I was going to build it without the Nut/bolt /Washer castings (NBW's).  Some of my modeling friends convinced me that the bolts were necessary.  So I did the math to find out that I would need around 1,000 NBWs to do boith sides of the trestle!!  I cheated and did only one side (facing the inside of the room) and the bents for a total of around 600!!  Didn't take as long as I thought it would.
Guy
  • Member since
    July 2006
  • 2,313 posts
Posted by gear-jammer on Saturday, January 10, 2009 11:19 AM
Guy,
Beefy swing gate.  I like the idea that it is adjustable.
Sue
Anything is possible if you do not know what you are talking about.
  • Member since
    September 2005
  • 66 posts
Posted by Geohan on Saturday, January 10, 2009 12:31 PM
The wear plate under the free end of the swing bridge will be key to maintaining alignment.  Should the hinges allow future sag, just loosen the screws in the wear plate and slip some paper shims under it and retighten the screws.  To unload the hinges when the gate is open, another landing fitted for that position would serve the purpose.
Just a thought, Geohan
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Saturday, January 10, 2009 12:40 PM
Geohan
Geohan,
That idea crossed my mind as well.  Unfortunately the gate contacts the opposite fascia (across the aisle) in the middle of a switch control panel (great model planing there).  So far I have been leaving the gate closed except when exiting or entering the room.  I may make a resting pocket for the gate in the open position someday, but it will necessitate moving the switch panel.....
Guy
  • Member since
    December 2005
  • 290 posts
Posted by germanium on Tuesday, January 13, 2009 4:58 PM
That trestle is a bee-yew-tiful piece of work ! Excellent,sir - my best compliments.
Dennis
  • Member since
    November 2008
  • 28 posts
Posted by Rusty Nail on Tuesday, January 13, 2009 7:56 PM
Beautiful work, like the old radio show "Give that man a Mars bar".  Having not been modeling for sometime, I am very far behind.  I have a question.  I like to scratchbild but never heard of RMC. Dunce  Would appreciate more info about them.
Anxious to see how your layout progresses.
Tom in PA
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Wednesday, January 14, 2009 1:55 AM
Tom & Dennis,
Thank you for the compliments.
The magazine is Railroad Model Cratsman.  They tend to focus a little more on the "craftsman side" of the hobby.  Here's a link
http://www.rrmodelcraftsman.com/
Guy
  • Member since
    January 2009
  • 10 posts
Posted by Grandtheft007 on Friday, January 16, 2009 11:31 PM
Hi Guy. You have done an excellent job there! Bow  A lot of food for thought. I'm getting to the stage where I will need to start construction on a swing gate. I hope you don't mind if I take some of your ideas and run with them.Whistling  Again this looks GREAT! Bow
Floyd
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Wednesday, April 22, 2009 1:12 PM
Sorry for posting so late, but I had not seen this thread before.  This is impressive and so creative! A friend of mine is currently rebuilding his layout and is considering building a lift section.  I'm going to make certain that he see this.
Excellent work, thank you for posting this Big Smile
trainnut1250
Another view:
Overview of scene:
Turntable update:
Scratchbuilt bridge
Guy
Swinging at you
Swinging away
Guy
"I like my Pullman Standards & Budds in Stainless Steel flavors, thank you!"
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Wednesday, June 17, 2009 12:20 PM
Added new material for those of you following along
Guy
  • Member since
    October 2010
  • 49 posts
Posted by RobertB. on Sunday, November 28, 2010 1:17 AM
One question I have here, the swing gate looks like the gate I will need in my Man Cave for my entrance/exit door, but how do you facilitate the connection of the rails when the gate is closed?
  • Member since
    July 2006
  • 4,565 posts
Posted by cowman on Sunday, November 28, 2010 3:33 PM
One thing you want to be sure of is that when your gate opens the power shuts off to a section of track each side of the gate making it impossible for a loco to take a dive into  space.
If you go to the right side of this page, scroll down to Search This Community, search for the term "gate"  you should get many, many ideas and photos.
Good luck,
  • Member since
    August 2006
  • 1,519 posts
Posted by trainnut1250 on Sunday, November 28, 2010 5:48 PM
RobertB.
Robert,
I have a wire going to the gate from the hinge side that powers the track on the gate.  It flexes with the gate as it opens and closes.  The rails themselves do not make electrical contact on either side.  They are powered from the gate itself. (hopefully that is not confusing)
I have not put in safety sections (dead zones) that prevent trains running into the void on either side yet, but it would be a good idea.
Guy
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
