Hello All,
Ok so here is what I am wondering alot of you talk about using styrene for scratch building or whatever you need really. What is it and where could I find it? The only thing I have been able to come across is foam board which is obviously way to thick to decent buildin work. (it works for now to mock up things) But I would like to really get into some more detailed work on my buidlings
You can buy small sheets at hobby shops, Plastruct and Evergreen are the two most common brand names. They sell 6x12 inch or so sheets from .005 to .080 in thickness. Plus they sell "textured" sheets that simulate other materials (clapboard, brick, corrugated metal, metal roofing, car siding, etc).
You can buy it a a plastics supply house, the one near me sell 3x5 ft sheets of .040 or .060.
You can buy it from a sign making company or as several people have suggested go to your local big box store (Walmart, etc.) and buy a sign ("For Sale", "No Parking", etc).
Dave H.
Dave H. Painted side goes up. My website : wnbranch.com
Evergreen and Plastruct also offer a wide variety of shapes and details as well. You can get sheets of simulated bricks, stairways and railings, a variety of sizes of beams, channels and angles, and plain strip stock in square or rectangular profiles from small to large.
Here's a couple projects I've done employing styrene in its many moods...
I used Evergreen corrugated sheet for the walls, "board and batten" siding to simulate a raised seam roof, and tile sheet to simulate the sidewalks.
This "still in progress" round house project uses H columns and I Beams from Evergreen, plust more of the corrugated siding and strip stock for the window frames. Plastruct brick sheet will provide a skirt below the windows.
Plastruct brick sheet forms the basis of this model. I use layers of it to create the relief of the brick work. The foundation and cornices are Evergreen sheet and strip stock.
Basically, you can use it to create everything from Hoover Dam down to the n scale 2x4 being loaded into a tiny pick up truck...
Lee
Route of the Alpha Jets www.wmrywesternlines.net
Trax21 wrote:Hello All, Ok so here is what I am wondering alot of you talk about using styrene for scratch building or whatever you need really. What is it and where could I find it? The only thing I have been able to come across is foam board which is obviously way to thick to decent buildin work. (it works for now to mock up things) But I would like to really get into some more detailed work on my buidlings
http://www.evergreenscalemodels.com/
http://www.plastruct.com/
If you ever work with wood.
http://www.gatewaynmra.org/articles/sheahan-wood.htm
If you ever fall over in public, pick yourself up and say “sorry it’s been a while since I inhabited a body.” And just walk away.
Hate to sound like a broken record but what Dave H. said. This is scratch-built with a "for sale "sign from wally's:
The walthers one is in the background.
Terry
Terry in NW Wisconsin
Queenbogey715 is my Youtube channel
